T-62typhoon
Hey everyone, I'm new to the site, but not new to the Typhoon. I've got a question? Has anyone done the front/rear brake conversion from baer? Or is there a cheaper route.......
Thanks
Thanks
T-62typhoon said:Hey everyone, I'm new to the site, but not new to the Typhoon. I've got a question? Has anyone done the front/rear brake conversion from baer? Or is there a cheaper route.......
Thanks
BLKLS2 said:I purchased the 13 inch front rotors and 12 inch rear rotors from a 1995 corvette and the same pbr front and rear calipers that baer sells was told it was the same stuff in there kit all from a c4 vette .Now I must call baer and see if they will sell me the brackets but it all seems to be fitting correct at this time .So maybe you can look into this setup . Got the calipers from my dad for free and bought the rotors from ebay that are slotted and cross drilled also hub areas were powder coated red all 4 for $150 shipped cheap! I will let you know when it is done and how it stops Good Luck !!
dutchty said:Hi
I've done the Baer rear conversion the 12" slotted/drilled discs.
The brake calipers are made by PBR (australia)and are altered by Baer for the handbrake system and are complete delivered with al brackets and brake lines, bolts etc.
I also added the anti groan damper kit on the rear Baer kit.
The same calipers are also used on the vettes.
There is also a kit from www.stainlesssteelbrakes.com and www.p-s-t.com but they have just 10.5" -11" brake discs when I purchased my Baer kit, so your missing 1" of stopping power.
On the front I've done it completely different
I've bought the www.cbrperformance.com C5 brake conversion kit.
and all the Z06 calipers and stuff with 13" Baer brake discs bought at www.paceperformance.com
The CBR is not just a bolt on kit, you have grind and cut on the spindels but it is the easiest way and complete delivered with bolts and wahers and easy to do.
Also you need to replace the wheels with some 18" wheels for around $900
There is also a BAER ultimate front brake kit with a 4 piston caliper for about $ 2295 for the real race enthousiasts.
But this is real stopping power.![]()
Goodluck with your upgrade.
If you have question, just ask
