Ryan Heller
Hi. My name is Ryan. I have a '91 Syclone. I believe that the VC is bad. I've done all the research on all the tests, I jacked the truck up and pulled the front propshaft. I feel resistence but for some reason the truck doesn't seem like it has AWD. I went to the track today and the rear tires were spinning at 2 lbs. of boost. But prior to this, I believe the VC was locked because I could feel it dragging like it was in 4WD. Any suggestions?
Little bit of info about my truck:
4L80E swap
alluminum rear drive shaft
front propshaft
RPM coilover front suspension
(these are the only mods that I think would affect this)
Any suggestions and comments will be greatly appreciated!
Thanks, Ryan
4L80E swap
front propshaft
Thanks, Ryan
