Loeryder
Few things to note that are new and improved.
Startup of our 03 balance shaft mutt motor went well.
Build:
SRP Pistons
Eagle Rods
ProGram 4 bolt mains
Cometic head gaskets
Vortec heads w/ Ferrara stainless valves
Isky cam / Isky springs and retainers
60# injectors
20G/10cm ported and modded turbo for JSM 3" DP
Ostrich 2.0 and code $59
Just had the A/A tubing and bov welded and got the side exit exhaust and cat mounted and hung.
Its louder than stock...
Old stuff:
RPM Coilovers w QA1 shocks
JSM trans and torsion delete tubular x members
Prime Gears stage 5 700r4 - hummer 4L65 planetaries, 7 clutch stack, kevlar band, modded valve body... whatever that means...
Hughes 3k stall
PBR (Baer) 12" 4WDB
17" OE Concepts z06 replicas w 255 Michelin pilot sports all around
PPG Repainted original Green/Grey
shaved antenna, B pillar and C pillar welds, roof rack delete
Goodmark 2: cowl hood w chivers prop rods
ghetto
chromed GMC letters bc idgaf
Corbeau TRS buckets on Wedge Engineering sliders
Speed Pro Indiglo gauges
Lotek 3 - 2 5/8 gauge pod
DashMat "Typhoon" embroidred dash and RK Kustom embroidered mats and cargo mat
Hoping to get my WB in and get inspected so i can get plates in the next 2 weeks.
Current tag expired in 2008 so its been a bit in the making.
I have reserved my old tag "MR TY2U" under the premise I will be legal soon!
We made the maiden voyage to the gas pump Friday night and nothing broke!
I am definitely pumped to be a member of the running truck club again and only using jackstands on my terms, not his.
And there is a JSM 4 Link sitting on the bench about to find a home.
You won't be seeing this truck at the Nats, unfortunately. :-(
Build:
SRP Pistons
Eagle Rods
60# injectors
Old stuff:
Hughes 3k stall
PBR (Baer) 12" 4WDB
ghetto
