AWD and brake proportioning
cthulu
Hey guys, I've building a LQ9/4l80/BW4472 combo and it's going on a 91 Bravada chassis. Working out how I plan on doing brakes, keeping the ABS on the Bravada chassis seems difficult due to the computers and such.
Can I use a standard brake proportioning valve for the awd setup? In the past I've used these for 2wd vehicles then just gone out and had a spotter tell me which wheels are locking up first. But with AWD I'm unsure if this method will work or not.
What do you guys do for your trucks?
Syclone#2960
What ever it takes!!
Im using a wilwood proportioning valve setup on my AWD sy...I dont think its going to be an issue but I did delete the ABS.
cthulu
Thanks man, some research led me to a similar conclusion.
Mephisto
These trucks are cursed
You wouldn't happen to have the part number of the Wilwood valve you used, would you? I just removed the ABS and installed the CTS-v brake kit up front, and I can't get the brakes to lock up. I've flushed the whole system, replaced the master cylinder and the brake booster, and have bled the lines 4 times, and still no dice... All that's left is the proportioning valve. If that doesn't fix it, then I dunno what the problem is.
This is an old post but I was curious if the proportioning valve fixed your problem? I have the same problem but I have already replaced the proportioning valve with a wilwood. I was about to start looking at the booster when I read this...
I have Wilwood recommendations for front calipers, MC, and PV - all parts are Wilwood's. The rear brakes are stock drum brakes with very little wear. The pedal goes to the floor when the engine is running. I get a firm pedal when engine is off.
wildphil
I Love My Ty's
