Autometer gauge cinnections?
jimhrabe
Ive got autometer oil pressure and temp gauges both are electrical and Im not sure where the best place to add the sending units onto the engine.Where has eveyone else added in their sending units? I do still want to keep the factory gauges working also.Any info would be greatly appreciated.
Thanks!!!
ajt86
Re: Autometer gauge cinnections?
I usualy just buy Ts if the senders are the same thread as the stock senders. Screw the T in then pop one 9n each side. Im not sure if the 4.3 has unused coolant and oil ports
gstacky
That's going to be tough on a Sy engine. There are only a couple of places to get oil pressure, one on the back of the engine where the factory sender is, and one where the turbo oil line is. Water temp gives you a few options, but still not a lot of room. Each head has a fitting, the passenger side has the ecm temp sensor, the drivers side is usually available. The factory gauge sensor is on the intake up by the thermostat.
