Re: Anyone know which Composite Distributor Gears to use with a MSD Dizy
I did do a search I wasn't sure if you were referring to the stock or aftermarket dizzy, but I do have a built motor with a 422 in it, I used my original dizzy but my tuner is having an issue, the truck basically is shutting down at about 4k RPM and at 11lbs of boost, up until this point the tune is perfect, I have msd 8.5 wires, new cap/rotor/coil, we tried re-gapping the plugs with no luck, he wants to replace the dizzy, and I want to use a composite gear so there are no future issues.
