Anyone have braided fuel lines?
LowLife
Previous owner apparently bent the H3LL out of the lines on my Ty :tdown:.....mostly where they connect to the fuel filter....both sides (from tank and towards engine).
Thinking about replacing everything from tank forward with braided lines.....I see that RPM sells a kit....is it better to purchase a kit or just piece it together with parts from Summit?
Difficult to install? Thanks!
Captain Morgan
Moderated User
Re: Anyone have braided fuel lines?
if you havent done braided lines before, it might be better for you to buy a kit and save yourself some time.
i dont know the price of his kit, but I would have to imagine doing it yourself would be cheaper, but naturally more labor involved.
Installation should be the same either way, remove old, install new, heh
blackty
A long time ago Hood had mentioned that he used soft copper tubing for fuel lines. I pm'd him to see how they were holding up. He replied great. So when I replaced the tank and sending unit, I ran 3/8" od soft copper and bought the correct GM X flare fittings from Earl's Online. I also put pipe insulation on them to keep from chaffing. Been 2+ years and no issues...Jim
V8 Sonoma GT
Mile High SyTy
i use that soft copper for work, and although it may be cheaper/easier, i would go with the braided line
Syclone#892
I would recommend staying away from braided fuel lines unless you plan to use teflon lined all the way which gets very expensive
http://www.pro-touring.com/showthread.php?62575-braided-fuel-lines-took-a-crap
I had braided lines on my sy and it always smelled like gas and I hated it. I am replacing my braided lines with 1/2 stainless hard line and teflon lined hose at flex areas.
I have heard of many people using the aluminum fuel line also but never heard of copper on a vehicle before.
I though classic tube or inline tube has a file to make up new lines so maybe check with them for stock applications.
Good luck with the fix :)
2kwik4u
Resident slow guy
http://www.maxchevy.com/columns/parsons/iii_6-parsons-1.html
Interesting link from the previous link.
PTFE is Polytetrafluoroethylene....the T doesn't directly stand for Teflon. Teflon is a brand name of PTFE from Dupont.....eh, splitting hairs, just a chemistry lesson for the day :D
I always thought stainless braided seemed expensive for what you got anyway since it was essentially "fancy covered" rubber hose.
