ShuggsRR said:Hmmm so from what you say I may have no highway with 3.73s...
LT1, 4L60E, 3.73s, AWD open front locking rear...
Yeah, you're right, its .696:1. And 1st gear is 3.059, 2nd is 1.625, 3rd is 1:1HotRodV6 said:for the record the OD ratio in the 700R4/4L60E is a .70
JustDreamin said:Yeah, you're right, its .696:1. And 1st gear is 3.059, 2nd is 1.625, 3rd is 1:1
For some reason .67 stuck in my mind, but its not correct. Granted, its only off by 2.6%, but it's off none-the-less.
Shruggs.....I'd suggest you find a good gear ratio calculator (there's a bunch online) and play with various ratios until you have a warm fuzzy feeling. You'll need to determine your tire size (if you haven't picked one yet) because that'll have a not insignificant impact. I'd suggest you look at all the gears, too. Compare road speed to rpm in 1st gear and 2nd. 3.06 is a pretty deep 1st gear, may be more than you want (not that it's easily changed or anything). Might even want to look at the rpm drop between 1st, 2nd, and 3rd (just to see how big a drop in rpm is. Then you've got to factor in how tight your converter is or isn't to see how it'll respond on the street. Awful lot of things to consider....
'JustDreamin'
JustDreamin said:You'll need to determine your tire size (if you haven't picked one yet) because that'll have a not insignificant impact.
That's the tire size I'm planning on running on my Bravada. OD is 26.7" or 778 revolutions per mile.ShuggsRR said:275/40/18s just mounted em this month!
JustDreamin said:That's the tire size I'm planning on running on my Bravada. OD is 26.7" or 778 revolutions per mile.
Just to be nosey, what tire did you pic (since there are a bunch)? What wheels are you running? I'm leaning towards the Kumho ECSTA ASX myself, on 18" C5 wagons.
'JustDreamin'
Cool....Need any spacers?ShuggsRR said:18" C5 wagons as well.
I did the Falkens
JustDreamin said:Cool....Need any spacers?
Sorry, this borders on hijacking your thread....
'JustDreamin'
I don't think I put that right. What I wanted to know is did you use any spacers???ShuggsRR said:yeah in the rear I suppose
JustDreamin said:I don't think I put that right. What I wanted to know is did you use any spacers???
'JustDreamin'
