Short block never fired, heads were reused from my last build.
91 4.3L V6 engine block
- Bored .040 over
- 2 bolt main
- stock crank .010"/.010"
- New Brass freeze plugs
- Block clearanced for Eagle connecting rods
- new hydraulic roller lifters
- obviously all new gaskets
- Icon 2618 alloy dished pistons (IC726+.040)
- Hell Fire piston rings
- Eagle H-beam rods (floating pins) w 7670 bolts (Part# CRS570063D)
- New bearings P-Series bearings
- BBC Melling High Pressure high volume pump (M-99HV-S)
- Hardened steel oil pump drive
- Reciprocating assembly balanced on Hines machine by Crankshaft Craftsman
- Cloyes double roller timing chain
- Performance hydraulic roller camshaft 112° lobe sep/ 210°/214° dur @.050", .478"/.487" lift,
- big valve vortec heads with matching springs for cam(2.02/1.60)
- ARP 3/8" rocker studs (stock vortecs where metric so this is a conversion stud)
- Syclone/Typhoon head gaskets (thicker also stainless core)
- BHP cylinder head floor work after 2.02/1.60 valve install
- 4 barrell Vortec intake manifold (cast iron)
$1500.00
- Bored .040 over
- 2 bolt main
$1500.00
