Another Rim question
japantyphoon
Hi there,
I was wondering if you could explain what wheel offset I would need if I was to purchase some rims. I have been playing with the wheel calculator and just want to make sure i am doing this right
for a 17 inch rim front by 9.5 inches
i could use the following offset with no problem
a 56mm offset, but it will stick out 4mm (how does this look with it sticking out 4mm?)
for a rear rim 17 x 11
a 50mm offset but it will stick out 1 mm (how does this look)
Sorry, I know this has been asked a thousand times, but I just want to make sure this is correct on using the rim calculator
thanks
Don
