10secTy
Sy-Ty builder and Tuner
Just to make this simple.
Vortecs will make enough power to break a stock block stock crank motor.
Unported Vortecs have gone 10.71@126 at 26psi on Tonys truck.
If you do the math that is 600hp at the rear wheels.
With lower shift points and locking the converter in 2nd he has gone
10.9@128.5 at 21psi.
when we dynoed the truck we had gains up to about 25psi then after that we had gains but not as much they tapered off.
The bottom line is that I feel his turbo was maxed out and not the heads.
If he had better heads it he would have maxed the trubo at say 24-25 psi instead of 28psi.
The Vortecs have alot going for them price wise, driviblilty, reduced Deto.
If you have a bowtie block and billet crank look at aftermarket heads then.
Oh and for the Record the Vortec V8 heads and V6 heads are not the same.
The port sizes are different.
Nolan
Nolan
