NOJIMMY
I sent the following information to Jeff (the tech inspector) at Bandimere (CO):
Answer:
There are no rules that compensate for the corrected altitude. In classes in Stock, Super Stock, and Competition Eliminator, where vehicles run on a specific index, indexes are factored for the altitude. Classes with superchargers/turbochargers are have a smaller multiplier to adjust for altitude. Here, we typically multiply ET by .9405 to see a comparable time at sea level, and by 1.0563 to figure a sea level number for mph. These factors are cut in half for turbo/supercharged cars.
In E.T. or heads-up racing, there is no factor ever considered. This is more of a personal interest factor. We actually established NHRA national records at our track in the NHRA Sport Compact Series in 2005. Altitude was corrected to around 8,500 feet, however the quality of the track, and the fact these cars make their own air, allowed us to set 5 records that weekend.
- Jeff
Jeff,
How much effect does Bandimere`s higher altitude have on Turbo`d/Supercharged vehicles under boost?
Does NHRA rules "compensate" for air density, downforce, and the use of meth/alk mixtures used in these type of engines,
or is only carb`d vehicles affected? I realize cooling is an issue.
Syclone/Typhoon members at www.syty.net want to know, as most of our events are held at sea level
and if moved to higher elevations, it would be useful to know, (and begin exploring the use of higher octane
fuels, higher boost settings, wastegate adjustments, blow-off-valve settings, and such to "regain" lost hp/torque
if altitude has a negative effect).
thanks in advance
Larry Brown
Answer:
- Jeff
