THEMADTYPH00N
I've recently fired up a new build on my Typhoon and I have ran into a problem with the alternator not charging.
At first I thought the alternator may have gone bad. I took it to a local rebuild shop and it was verified that it was working properly. Next I thought that possibly the powder coated alternator bracket was not properly grounded to the block. It was, however I cleaned all of the mounting points anyway just to ensure a good ground. Also for trouble shooting purposes, hooked up a temporarily ground wire from the alternator case to the block just to ensure good ground. Nothing changed.
Next I looked at the plug from the engine harness. It has two wires, a tan/white that has 12v when the ignition is on and a brown wire that (if I'm reading the diagram correctly) goes to the battery light in the dash. I thought maybe I was not getting good contact, so I removed both terminals from the harness connector and slid them onto their correct prongs on the alternator. What I've discovered is that when the exciter wire (tan/white) is hooked up by itself, the alternator works and I get a steady 14.6v. However as soon as the brown wire is hooked up the alternator will stop charging.
The other weird thing is the battery light never comes on whether the brown wire is hooked up or not. I'm not ruling out that the bulb may be burned out as this truck has been sitting for awhile.
Any help would be greatly appreciated.
