Alternator and wiring
Static
I am in the process of upgrading to an AD244 alternator. I bought the CS to AD adapter pigtail, got it all mounted but it does not charge. I connected the S terminal back to the alternator output thinking that may be it. I have 12v at the F terminal but no voltage to L. Should I have some voltage on L?
Static
Re: Alternator and wiring
Yes this is what I needed. So I need power on L with resistance in line. Currently have power on F so I can switch those 2 and add a resistor. So my next question is, since the Ty harness has only 2 wires F and L where do these wires go to in the truck?
Static
Thanks for the help Dave. I thought for a minute I would ohm out the brown wire to see how much resistance it had. I know some of the old GM vehicles used to have resistance wires for some stuff. Well anyways I got a 1/2 watt 470 ohm resistor from Radio Shack wired it inline with L to the pink wire and everything is charging as it should. Going to be installing efans soon and eventually a 2500 watt RMS stereo. This one is supposed to be 250 Amps. Cant wait to fully test it out.
Davemc1963
93 Ty Owner
So when the original alternator craps out, is this the 'way to go', or are there other options for these trucks. I presume looking at the pic, it is a straight forward bolt on, obviously I mean bolt on with the wiring mods detailed. I haven't searched, I was just flicking through todays posts and saw this one, so thought I'd ask the question.
