Air filter on turbo
(V)erciless
TURBO6
Ok did some searching can't find a post sooo...
Anyone running an air filter right on the turbo inlet? If so what brand and what where the measurements? I am trying to get on the Team green filter site and the K and N and both are not showing up. :squint:
Aeroking
e.i.
Re: Air filter on turbo
APC cheap air filter available at any AdvancedAuto or Pepboys for $20
shown on a 72mm, so you'll have more clearance with a stock turbo
(V)erciless
TURBO6
Perfect thank you. Do you have the measurements on that filter? I would like to run a Team Green filter.
Aeroking
e.i.
bigger filter surface area is best. but if you need to fit something in, the APC filter will work.
i've since switched to a 4" cobra elbow and a 12" long K&N cone
i8av8
i actually ran into a problem with a short filter like that "$20" one. not knocking it, but every vehicle IS different. it was holding me back. "choking" if you will.
so now i am not running a filter at all. what i have is a wire mesh style screen with one sheet of k&n cotton filter sandwiched in between. to each their own.
turbodig
Just an FYI... filter right on the turbo = lots of heat in the intake air. That's the hottest area of the engine compartment.
I call BS, just gotta move the turbo a bit.
(V)erciless
TURBO6
Someone had a pic of a Sy running low ETs with that type of filter. Can't remember who it was though.
Aeroking
e.i.
i believe the BadNewz Sy was running a HKS mushroom, but the turbo was positioned so that the air filter was exposed to the grille in the front.
SY2932
Administrator
Might have been Charles Bloosom (from the '02 NATS in Chitown):
His truck ran 11's all day with stock turbo.
Typhoon #2131
SAVE THE TA-TAS
thats nice. I wish I would have known this before I bought my K&N cone filter and placed it on the end of the cross tube. Dose it make it whistle more being right off the turbo like that?
tydye
Banned
its prone to suck more dirt this way as well aint it? i like the idea of cold air grabbing air that isnt exposed to all sorts of dust and debri, although i had looked into one of these because it would be nice to empty out that whole area under there.
Fighting5thSVT
[/IMG]
[/IMG]
I run mine with a Braille lightweight battery right underneath it. I got the filter from RPM.
