AC delete my way
Vasplieon
It runs; just not right!
I just wanted to share an easy way to delete the AC from your syty while cleaning up the pass. side of the engine.
Basically all you need is a pulley off of a 97 GMC jimmy, a 200 amp alternator and a 53" goodyear gatorback belt (6PK1345). You just drill two holes in the accessory bracket (one for the bolt and one for the nipple) and mount the tension pulley, install your 200 amp alternator and put on the belt. I have not had any problems with this set up.
Check out the pictures.
http://www.novatechnologysolutions.com/syty/AC delete/ac1.jpg
http://www.novatechnologysolutions.com/syty/AC delete/ac2.jpg
http://www.novatechnologysolutions.com/syty/AC delete/ac3.jpg
http://www.novatechnologysolutions.com/syty/AC delete/ac4.jpg
http://www.novatechnologysolutions.com/syty/AC delete/ac5.jpg
http://www.novatechnologysolutions.com/syty/AC delete/ac6.jpg
Here is the url for the 200 amp alternator for 250 bucks
http://superpageshosting.com/4alter...ting.com/4alterstartcom/highoutputalternators
SY2932
Administrator
Re: AC delete my way
Very nice setup :cool:! Now there as no less than four methods to completely deleted the AC for the folks who decided that they can live without it.
TYTILIDIE
METH HEAD
Im impressed. Thats looks very good and seems easy. I'd love to say it sucks because you have to spend $250 but I guess you can't go wrong with a 200 amp ALT right?
Tophatjimmy
Syclone FNG
Shouldn't cost that much if you use all boneyard parts.
I can get a 126 Amp OEM CS-144 (GM Large case) alternator at the pick-n-pull for $8.
Vasplieon
why do you need the 200 amp alternator?
You just need a large frame alternator because a smaller frame needs a belt length of about 51 3/4" due to pulley location, which they do not make in a gatorback (they may in some other brand thou I just did not try to look). Like the above individual mentioned he can obtain one for 8 bucks at the pick n pull so it does not have to be the 200 amp like I purchased (but 200amp makes a nice electrical system addition).
Vasplieon
Where is the second hole drilled and what nipple?
If you expand the first photo above you will notice a circle just to the left of the bolt with a 33 stamped on it. This is the nipple that keeps the pulley secure (otherwise it would just spin on the bolt).
Vasplieon
does it have enough tension on the waterpump to keep it from slipping at high rpm?
I have not had any problems yet with this set up as the belt comes in contact with about a third of the circumference of the water pump pulley. I have watched the set up while checking to see if the timing was changing at 4500 and I did not notice anything strange at that rpm. Also this is with a used pulley and no belt dressing too so if you notice slippage you can try these, but I have yet to need them.
TYTILIDIE
METH HEAD
If you were to search for this alternator in a junk yard, what car would you be looking in?
FxsX24
94 S10 to be lowered/v8
anyone that wants to do this with the small anternator
autozone has the 53.74in belt
Part Number: 4060537
Weight: 0.3 lbs
Size: 6 ribs 53.740 inch. Effective Length
i will try and install this setup tonight
FxsX24
538k6 (53.8in 6 rib) is WAY short for the normal alternator
91 s10 ps pump
91 s10 crank pully
90s 120a alternator ( i think)
is there any load on the tension er
whats the diameter of the pully on the alt?
SY2932
Administrator
Exactly what alternator do you have? Is it one of the ones below?
"CS-130 (stock) on left. CS-144 on right."
Getting the right length belt is easier than falling in love if you have a measuring tape like tailors use. Just route it across the pulleys and measure the length taking into account tension applied by the tensioner that you are using.
hardtailcfl
So I got ambitious tonight and did this mod. It's actually fairly easy and went smoothly. I measured out a belt size and figured roughly 56" or maybe a little less. I'm going to pick up a belt tomorrow and I'll report back with what I find :tup:
Vasplieon
The CS-144 looks like the frame of the one I am using with the stated belt.
