http://syty.net/phpBB2/viewtopic.php?t=21097
http://syty.net/phpBB2/viewtopic.php?t=23029
http://syty.net/phpBB2/viewtopic.php?t=23403
I got that part number from gmpartsdirect.com. They charge the dealer cost (or whatever) $221 for it, then make their money on the standard 10% shipping or whatever. It's still way cheaper than the $442 retail on the part.
The part swapped in perfectly as far as fit goes. The bearings in the old one totally gave out or something. The shaft and pulley or whatever shifted down and crashed into the outside pulley that the belt rides on. The whole thing was siezed up completely, so the belt couldn't turn at all with that compressor there. I didn't want to mess with the orifice tube and all that junk, though I bought those parts too. It wasn't high enough priority to finish getting fixed, so the new compressor is installed and unplugged for now (drivable but no A/C). Can't tell you anything about the switch to R134 (yet). I did lots of reading, and apparently old R12 parts work a lot better on R134 than new R12 parts. The R12 stuff soaks into the hoses and stuff so the smaller R134 particles don't leak out as much. Brand new R12 parts are more permeable and don't have the R12 oils to seal them up. The review I read said that it might not be the most efficient, but that you should basically be able to just swap in the R134 in place of the R12.
Here's a crappy pic of what happened to me...
You can easily see the black metal ring, which is connected to the triangle part via those riveted strips. Between the rivet and the mounting bolt, you can see the edge of the belt pulley part. It's the silverish part between teh rivet and bolt head there. Because of the angle of the camera, it's sort of crescent-shaped, "disappearing" into the compressor at the bottom. Anyway, if you follow that lighter part up around from the bottom, you can see that there's a notch missing from its roundness right there between the bolt head and rivet. That's what I had to grind out just to get enough clearance for the bolt head to get it out. Yes, the flat side of the bolt head just barely cleared it after I ground off that much.
