abs wiring removal
MyNewSy005
Re: abs wiring removal
They connect just uner the battery tray via a weatherpak connector. easy to take off. you could leave the opposite end of the weather pack to the battery and ground wire if you ever want to return it.
warmpancakes
Thanks :tup:
WyoSyclone
warmpancakes said:
Thanks :tup:
I thought there may be something strange going on with them... I've been looking at the factory schematics a lot lately... MyNew is absolutely right - directly to the battery... I think I'm going to use mine as a B+ and ground for my Alky system - going to see if Renz will fab a flat bracket to mount in place of the ABS cage, to hold the alky pump.
