ABS light on
eqs_sy
I have the abs light staring me in the face. I have reset it but it comes
back at different times.
I pulled a code 45.
The SportsMachine website says that:
Code 41 through 66 4WAL control unit or motor circuit Check for a loose
ground connection at the motor circuit. Clear the code and drive the
vehicle. If any of these codes return, the EHCU valve may be faulty.
The grounds are OK I think (which grounds are they referring to?). Is the EHCU valve expensive?.
Thanks
InvisiBill
I believe that's an internal part of the ABS module. So yes, it would be expensive to replace.
Do a search. Many people (myself included) have fixed ABS lights just by flushing the system with a LOT of new brake fluid. I believe I used about 20oz on mine... I also found a description in one of my manuals about how to open up some valves inside the ABS module itself to bleed those out. A search should bring it up...
