Re: abs help
QUOTE=Reboosted:O.K. just repulled the codes. 43,44,54,65,66,86 and a new one 27. Now both front wheel senesors are new, so want to test the front left harness. My book says in the 8 way connector L.F. is b yel and f dk grn. Does that sound right?
Response DaveP: My book says yel and lt blu. Just look in the harness at the sensor connector. 86 can be set by riding the brake pedal, or brake light switch adjustment. Be sure pur wire (pin C) has 12V with brake not applied.
I am pulling these with a jumper wire, so I think the antilock warning lamp is O.K., or am I wrong?
No, you're doing it correctly.
Background on the truck. When I first got it, the grounds on the back of the head were disconected. When I connected them, I got codes for both front sensors. I replaced both of them and it was happy for a few months.
It's intermittants, then. Or a control valve (41-54) is stuck, which will not allow codes to clear. Try a few things: Run the motor by pulling the connector for it, and applying 12V directly to the terminals TO the motor. Be sure it runs. With it running, MASH on the brake pedal a bunch of times. In frustration, I even smacked the BPMV with a hammer a few times, with the motor running, and it fixed itself! Be sure the bleeder by-pass valves (on the sides, brass 10MM hex) are closed.
There's some ideas. They came from my experience with my Blazer, which has AWD, and a SyTy BPMV. It was fine for 8 years, and after I let it sit for about 12 months with little use, it was doing the same thing yours is: Lots of codes, which wouldn't clear, and all it did was sit. This is the one I hit with a hammer, and it's been fine for about a year, now.
Dave
