ABS help
Slyclone
Well-known member
Re: ABS help
Turbo tuna Check post #9 on here first page. I posted it. Pics are gone but might be worth reading. Couple members had luck, while someone else said the buttons don't do shit. I think its worth checking and trying
10wetwillys
Re: ABS help
Thanks for briging this post back up.. I also have a abs light on, just check the buttons that are on the abs unit ..one was pop out..
turbo_tuna
Re: ABS help
Thank you all for posting. I was able to clear the codes using the following procedure:
To erase stored fault codes, a scan tool or the following manual procedure can be used.
1. Turn the ignition switch on.
2. Connect a jumper wire or key between diagnostic connector terminals "H" and "A" (or ground "H") - and wait two seconds.
3. Remove the jumper wire for one second.
4. Repeat the grounding for two more seconds. The ABS warning light should go out if the codes have been successfully erased.
Note: The codes would not clear using the jumper between A and H. I actually grounded the H pin instead of jumpering and it cleared.
This procedure is necessary only on certain hard codes. Soft codes can be cleared by correcting the system problem and turning the ignition off for approximately five seconds.
To obtain codes jumper A and H and count as you would for engine codes.
I can not tell you now nice it is to drive with no indicator lights on the dashboard. I became used to them being on.
Hope this helps the next guy!
