Re: ABS delete kit
I found some written instructions in one of the other threads. If your truck is like mine, there are two lines for the front brakes. You have to remove the union from one of the lines (located on top of the driver side frame under the wheel well). Replace the union with a Tee. Route the other line to the Tee (which means cutting, bending, and flaring). Auto zone has the Tee and a flaring tool for loan.
Then the kits installs. Large line from the front of the combination block to the rear and the small line from the back of the block to the front Tee.
