ABS Delete Kit - Catchup Run
turbodog
Re: ABS Delete Kit - Catchup Run
Got mine, Mike, Thanks.... and just in time, too!
I installed LS1 rear discs recently, and in the process damaged my right rear ABS sensor. So, I've been driving it with the 'anti-lock' light lit and no ABS until I can get around to installing a replacement sensor (actually a late-model sensor, which is much smaller... but that's another story, ur, thread). I bought Mikes kit just in case my replcement ABS sensor idea doesn't pan out.
On my way to work, I'm pulling up behind a car at a redlight when the abs starts pulsing the brake pedal, I glance down and the 'anti lock' light is OFF, and our wonderful ABS is about to cause me to rear-end this unsuspecting person in front of me! Just in the nick of time, the 'anti-lock' light comes ON, the pulsing stops, and normal braking restored in time for me to stop short of a collision.
Apparently my ABS started getting just enough signal from the damaged sensor to try and operate, but the signal was weak or intermittent so it also decided to engage the ABS.
I can't think of a better demostration of how ineffective our (or at least MY) ABS is. I was on dry, smooth pavement, and the instant the ABS kicked on I could feel the deceleration forces drop dramatically. The ABS turned a routine stop into a heart-stopper. Guess I won't be needing that late-model sensor after all....
AUSyTyIN
Unbusted $#it box
I have yet to recieve mine. Can you verify the shipping address?
sytyguy
Moderated User
Austin.....yours came back to me today. "No such number in Littleton, CO" is the sticker they put on it with a return to destination number of DEN1041791859.
I used the address you sent me (actually copied and pasted it off the message).
Wanna try another addy or did we mess up this one (I sent you a PM with the addy I have)?
Hood
AUSyTyIN
Unbusted $#it box
Hood
Problem found, PM send (before I read this, actually).
sytyguy
Moderated User
Okay....I think I have everyone taken care of. I have a couple of kits set aside for the FAST guys, but everyone else should either have their kits or will be getting them in 2-3 days. If anyone HAS NOT received a kit that HAS been paid for, please reply here or PM me. Also, if you want a kit and have not paid for one yet, please do the same. Here are the most recent kits shipped:
Shane Delmore - 1 kit - Shipped 07/15/05
Jeff Scott - 2 kits - Shipped 07/13/05
I have the materials to make several more kits, so if any of you want a kit (or part of a kit), please let me know.
Thanks so much for everyone's business and patience,
Hood
nightdiver
Im waiting for the total, including shipping to pay pal the money.
Dont forget the window motors and hose :)
Thanks
CavScout
Mike, I am still waiting on the kit. Could you send it with the gasket set?
sytyguy
Moderated User
Sure thing man.....sorry for the delay.
Hood
VermontTy
Support Our Troops
Hood,
I don't mean to highjack this thread, but since there have been so many that have done the ABS delete that are subscribed to this thread, I thought this was a good place to ask....
How did you all mount your cruise control once the ABS was removed? I currently took the bracket off the ABS unit, mounted it to the fender, and have the cruise mounted to the ABS bracket, but it A) looks like ass, and B) is real flimsy. The cable is a fixed length, so you can't just mount it to the fender. If anyone has pics, or a description, I'd appreciate it. Thanks.
-adam
jwaller
Evil Genius/SyTy Guru
VermontTy said:
Hood,
How did you all mount your cruise control once the ABS was removed? -adam
just get rid of that too.
. I know thats what I did.
VermontTy
Support Our Troops
I knew that was coming....ditch A/C, heater and ABS but keep cruise? Call me a sissy....:D
VermontTy
Support Our Troops
Also.....did you all just cut the plugs / wiring for the ABS unit and all the sensors? I don't see any nice place to loop it all up for use at a later date if someone wanted it....
I ditched the cruise never used it anyways (I am more likely to fall asleep on long trips) The wiring I tucked into the frnder and zip tied in a couple of places.
I tucked my ABS wires behind the oil filter adapter. Can barely see them. Probably wouldn't see them unless you look for them
cvcsmkr
hood.
just a reminder, haven't recieved the front line and tee.
no rush, wont be doing this until the winter.
but if you have a list going put my name on it.
thanks
jjorgensen52
NHSTE - I'm the only one!
Question is, will this abs delete kit fully replace my old lines, except the the front flex lines and the axle parts? Seeing as there isn't anything left of my old lines.... Also, could they be done in stainless hardline?
