George Blake
DONATING MEMBER
Weird thing happened. Using A/C. Worked great. Dillon and I drove about 300 miles. Hottest day of the year. Last leg of the trip going to Dayton. Air gets friggen COLD. Drive it back home. Still friggen cold. Colder than normal. Engine temps go about 30 degrees over normal. Get home, open the hood to let the heat out.
Next day. NO air. Vents and everything work, just no cold air.
Thought my freon was low (converted to 134A about 8 years ago).
Went to put the gauge on the LOW side and the friggen needle flips ALL the way around to past 90 psi. Turning on air, got NO compressor engagement.
One of the guys at Napa tells me the little orifice screen is probably clogged.
Said to replace that, the dryer, pull a vac on it and refill it.
Does this sound right?
