Ok well I don't own a Sy/Ty, but I do have a 1994 Olds Bravada. Pretty much the same basic layout. I've looked around but you guys are the smartest I have found. Here is my issue, NO AC! It was 93f today and I couldnt stand to be in the car, ontop of that my Heater Core is leaking so I couldn't breathe. However I can fix the Heater Core. Below is a review of whats going on in the AC department.
1.) System is R12 no conversion yet.
2.) The AC clutch clicks on and off, seems to be at a normal rate.
3.) Accumulator DOES NOT get cold.
4.) When AC is on in car ambient NOT HOT nor COLD air blows through, just ambient temp air.
So any ideas what the problem is? From what I gather it is probably not leaking nor empty since the AC clutch pulley works. I heard when it gets low or empty that will turn off to prevent a burn out. Please help I can't sit in the car this hot, nor can I cart my 2 yearold daughter around in it when it is this hot. PLEASE HELP! THANKS!
