A/C pressure switch part number
The Dread Pirate Fisher
Having trouble finding which is the correct pressure switch. The one that came with the dryer is incorrect, the prongs are large and apart. My connector is round, small and 2 tiny prongs close together.
Searched here, didn't find much, there are numerous ones that show when looking up 93 typhoon in rockauto or gmparts,
Anyone have a part number #
Re: A/C pressure switch part number
Thank you for the info DaveP, although I don't remember offering 7500, I remember saying high 8's. I bought this truck for 6300, knowing I wanted A/C to be put back in, which is almost done by the way, and I have only spent $260 to complete it, just the small stuff left to do that's getting worked out. I had a 9k total budget, including purchase, I'm still way under. This being my 3rd typhoon, I should have saved my records and info on the last 2.
Back to topic, it appears the dryer already has the proper shrader valve, since it had this 134 valve, I guess I just need to convert the plug instead. I still have to take it to an A/C specialist to pull vacuum on it to remove moisture since the system has been open. I also got a better orifice tube at the advice if others as well.
I do appreciate all the help and advice thus far, I've enjoyed getting back into these trucks.
