A\C delete box
ty1435_4.3
Shes almost ready
Hey guys Im sure its on here someplace but I cant find it, I need to know how to hook up the 3 wires for the resistors on the box. Im almost with the change over and thats all that is really holding me you. Just need to know which wire goes were? TIA
fivetodrive
CRISPY
Re: A\C delete box
Just make an extension to use your current resiston or cut a hole in the box...
Here is a pic of the ones I make...
ty1435_4.3
Shes almost ready
Re: A\C delete box
cool looks good. But I already cut off the relay and other wires just need to know what goes where? TIA
jwaller
Evil Genius/SyTy Guru
Re: A\C delete box
put it back the way it was. nothing wrong with it and it will work perfectly.
SY2932
Administrator
Re: A\C delete box
Here's how I modified the hole were the resistor went on mine when I went ACless after a little "clean up":
I mounted my blower relay in between the resistor and blower housing on my truck but you can mount it anywhere that you want (preferably away from the heat of the downpipe). I just cut my plug off and extended the wires soldering and heat shrinking everything in the process. The fewer connectors that you go through, the better the connection :2cents:.
ty1435_4.3
Shes almost ready
Re: A\C delete box
Crap I cut off the relay .............. so I will keep the relay and work the hole for the old resistors. So I just cut off the wires for the dryer and a/c comp?????
