93 Typhoon 0529 ***UPDATED PICS ADDED***
The Dread Pirate Fisher
as I posted on the facebook page earlier this week, its with a heavy heart I need to sell the typhoon. I really don't want to, I have finally dialed it in and replaced a lot of bad things the truck started out with.
I bought it March 1st of last year from SocalBlue, formerly on this site. Truck came out of Torrance CA where it spent all of its life as im told. I never drove it in snow, we really didn't have any snow this year, so truck is rust free.
specs:
1993 Black/black Typhoon with Un-painted cladding.
I currently use it as a daily to work
current mileage is just over 136k.. I bought it with 132k so only 4000 miles in 1 year
Engine:
stock heads, block, intake manifolds
stock oil cooler and remote mount
RPM cold air intake
Jegs rail mounted fuel pressure gauge
AFPR
Lower intake manifold gaskets changed
Upper intake manifold gasket changed
silicone rubber vacuum lines
RPM braided brake booster line with boost gauge attached
EGR delete
Ignition:
New cap, rotor
New NGK plugs
New ignition module
Silicone wires
Brand new Starter switch
Chevy Performance mini-high torque starter motor, brand new solenoid
New 10 gauge purple wire with thermal wrap
144amp alternator conversion
Trans:
Stock trans, stock converter
Cooling:
New stock ACDelco radiator
180* thermostat
stock water pump
Astro Van 11 blade plastic fan
New fan clutch
Turbo:
Stock turbo, rebuilt with Mitsubishi rebuild kit 1000 miles ago
4 bolt conversion on turbine housing, puck removed
Braided AN cooling line for turbo
2000* thermal coated turbine housing
Manual Boost controller from BoostValve
Aluminum Charge pipe to intercooler
Stock intercooler
Larger custom aluminum Heat exchanger
Brand new Bosch 317gpm pump
Intercooler scoop
Exhaust:
Custom made (by me) 2.5" mandrel bent down pipe, 2000* thermal coated
AEM wide band
3" mandrel bent exhaust (built by me)
3" magnaflow catalytic converter
3" in/out magnaflow muffler
exhaust dumps before rear axle
Brakes:
front LS1 F-body conversion using RenzFab kit
rear LS1 F-body conversion to disk brake
Sportmachines ABS delete kit
New stock proportioning valve
Suspension:
Front, QA1 coilover conversion with Hypercoil 600# springs
Brand New Moog front Upper and Lower Ball joints
Brand New CV axles, complete axles both sides
Rear Gabriel Load lever shocks with coilover springs
Stock rear leafs
JTR 2" lowering blocks
JTR setback plates
Rear Belltech sway bar
Interior:
triple pod gauge holder
Autometer engine temp gauge
Autometer Boost gauge
AEM wideband O2
Stock seats, and very clean interior
Tuning:
TurboTweak chip, stock injectors, 91 octane setting, EGR delete
Heat/HVAC/AC:
I bought the truck with no heater/core/AC, I put the AC box back in, as well as a new heater core, and blower motor. AC was recharged last June, blows cold, heat works great.
I also replaced the HVAC switching vacuum selector, as well as replaced the vacuum lines behind the dash that come in from the engine (that was a BIG job)
Stereo:
Brand New Kenwood CD deck (I still have the stock 93 CD player as well)
Boston Acustic speakers
Wheels:
Stock wheels
stock wheel caps
Wheel cap bolts are not stock
Stock unused spare with tool kit and wheel cover still in place
Exterior:
white turn signals and corners
The Good:
Truck runs great, as I said I use it as a daily, no issues, solid boost, pulls great.
The bad:
leaks a nickel size spot of oil coming from the oil relocation at the block
Starter grinds every other start due to a few messed up teeth on the flywheel
AEM wideband gauge just stopped working, trying to figure out this issue
Trip odometer doesn't work
Hatch release doesn't work, needs to have solenoid replaced (I have a spare)
Needs front end alignment (I can get this done before sale)
I also have numerous other stock and aftermarket parts that will go with the truck
ECM, brand new window runners from Sportmachines, Sportmachines Turbo Blanket, hatch release solenoid, Drive shaft safety loop, Volvo electric fan, stock crossover tube with box
I also have a brand new ACDelco 3 bar map sensor, TurboTweak Walbro fuel pump, and TurboTweak Hotwire fuel pump kit all brand new in the boxes to go with this
truck located in Provo UT.. I can help deliver within a hundred miles or so..
Looking for $8000 firm
.. its well worth this or more. truck needs very very little.. paint is great, no major issues or rust.. there are 2 vertical scratches on the rear tailgate
pics to follow later
Re: 93 Typhoon 0529 ***UPDATED PICS ADDED***
this is the down pipe I made and its 2000* thermal coated
this is the back of the turbo housing with the puck removed, the new down pipe accommodates it,
Yeah if i can sell it in a week, this is the price, otherwise it's going on eBay and Craig's list at a higher price, tryIng to give forum members a good deal first
Quickstop [UK]
Combating adversyty.
That is clean and cheap. Awesome price for an awesome truck. Sorry you have to let it go man. GLWS.
ChiPhoon
Chicago Typhoon!
nice clean ty, someone buy this thing up and save big on some of those mods for sure! GLWS
ty1663
I wish you had posted this 3 weeks ago. I just bought Ty#0026 and i'm some what satisfied but for the price i would have bought yours NO QUESTIONS asked. looks good bro.
Yeah we live right up against Mt Timpanogous, you should see it from the alpine loop road!
Few days left, then it goes to auction
Damian
This is why I don't look at the for sale ads, I almost want to buy this.
atkonkler
Is this your bush?
Do it Damian ! Get rid of your jeep...that's a pile of wonder!:tup: looks like a great truck! Glws !
