dalwine250
92 syty long block .no manifolds . L35 heads with bee hive springs , stock rockers . block is 30 over and crank is 10/10 . TRW pistons ,main straps ,412 cam, melling pump. i pulled the engine out with 8k miles because of a very slight , hard to hear ,hollow sounding knock , checked the main and rod bearings and they are fine , maybe its a wrist pin or maybe i was hearing things , not sure. i also have a cabinet full of parts , 40k mile stock turbo ,instrument cluster bezel , good drivers door panel , stock downpipe ,glove box door , msd 6al with harness, heater control non AC , clear turn and side marker lites , trimmed cross over tube with air box ,single pillar pod plus a box full or ignition parts and map sensors ect.
$1800 takes it all , pick up only , located in southern michigan near south bend indiana
