to test for max psi unplug the vacuum line directcly from the wastegate, not the plug from the solonoid. I wouldn't ever recomend doing that because you will most likley spike upwards of 25 psi.Billow said:Thanks.. I was told that was a way to test for max psi.
I tried that on my rpm turbo on accident and I saw 32lbs for a split sec. I shut it down quick.mmp142965 said:to test for max psi unplug the vacuum line directcly from the wastegate, not the plug from the solonoid. I wouldn't ever recomend doing that because you will most likley spike upwards of 25 psi.
