9/11 TC Install Problem
I have the TC all seating in the tranny, fully seated. But now that I have the trans all bolted to the engine, the TC and flywheel bolt holes sit about 1/8" away from each other?? Can I pull the TC out of the pump 1/8" to push it tight to the flywheel???? This is the last step but this is throwing me for a loop?? Thanks Fern
myclone
Yes, move the TC up against the flywheel and put the 3 bolts in. Done
A fully seated TC will have a 1/8" to 3/16" gap between it and the flywheel before you bolt them togeather.
