80e Install Pics - Need Help
mrweelr
Re: 80e Install Pics - Need Help
I didn't mount mine at all. It's already wedged between a few other things.
skwayb
NWSTP
Mounted mine on the heater/ac box. 2 holes, took out the resistor to access the backside to add the nuts/tighten. Exercise in patience but it worked.
Pretty Much same place mine is.
This help
Quickstop [UK]
Combating adversyty.
thanks for the help guys! The pic and advice are perfect :tup: My box is off so I'm going to mount it there.
Quickstop [UK]
Are there different casings for the 4L80E? My trans lines seem to be both located together at the forward part of the trans on the RHS.
The trans dipstick is under them and the LOKAR dipstick doesn't seem to want to fit. Pic to follow but mine looks a bit different from some of the others I have seen on here.
On the plus side, the TCU spoke to it and the base tune is all set up for it.
EDIT: OK, so it was tight. I pressed down with a 16mm wrench while twisting it with a big adjustable. Better to install this in the trans when it isn't under the truck I think...
