780+hp V6 engine part-out
qbnkiller
Conflaguration Specialist
Well...the little 4.3L V6 has given up the ghost. The MAHLE pistons (4032 alloy) were never designed to handle this much abuse (I have been using them since 2005) and have finally let go in a spectacular fashion. I will be fully inspecting everything before it goes out. Here is what I have:
1996+ VORTEC heads with FERREA 6000-series 2.02/1.60 valves, ARP rocker studs, ISKY guide plates, 140# PAC springs, retainers, shims, 7* locks, 7.200 hardened pushrods, aluminum 1.5 ratio roller rockers, ARP poly locks. Custom grind BULLET cam (street-friendly and makes great power)CAM IS SOLD PENDING PAYMENT. Will include SCE Titan ICS full copper head gaskets (used but still absolutely fine). Heads have o-ring wire without receiver in the block. Will hold excellent amounts of boost (double o-ringed - call if you done understand). There is over $1600 invested in these heads. SOLD PENDING PAYMENT
Edelbrock #2114 VORTEC intake manifold prepped for injectors plus fuel rail. RPM sells this intake for $495 plus the fuel rails at $149. Save a bunch! Just add injectors, elbow, and throttle body. $425 SOLD PENDING PAYMENT
Eagle forged rods $325 SOLD PENDING PAYMENT
ARP head studsHEAD STUDS SOLD PENDING PAYMENT and ARP block studs and bolts. PRO-GRAM 4-bolt splayed mains (2). PRO-GRAM front and rear strap. $200
Stock exhaust manifolds with crossover - Swain coated and painted black (stealth look). T3 spacer with provisions for V-band Tial (or other) 44mm wastegate. $400 for everything obo
Stock V6 distributor (Autozone) with stock gear $25 SOLD
Full roller timing set $50 SOLD
Rhodes V-MAX hydraulic roller lifters #1156L $125 SOLD
syty oil pan $50
All prices are plus freight. PP accepted. Pictures to follow on Aug 20 or sooner as I have a trip to Los Angeles from Aug 14th through Aug 20. If you have an offer, PM me.
Thx.
berzerker
wookie
Re: 780+hp V6 engine part-out
i'll take the distributor off your hands . pm paypal payment info . and total shipped to 80013
qbnkiller
...you dont want my block! It is all the parts for the bottom of the block (main caps, studs/bolts, straps).
SEL777
One of 101
Alex, I'm interested in the lifters and timing set (if it works with your old cam I bought), can you check on the shipping for me?
qbnkiller
Lifters and timing set are the same ones. Add $15 for freight (priority mail)
jpalmer
This sucks man. You did well with this combo. Some great parts there. Proven to do at least 10's.
qbnkiller
...also, if you have an offer, PM me and we can discuss. I have had a few phone calls on items, so I wouldn't dilly-dally or you will miss out!
