58mm Turbonetics turbo
hutchensce
I have a 58mm turbonetics turbo for sale. I believe this is an RPM Stage 1 turbo (at least, that' what it is according to the former owner)
I really don't know a lot about this turbo...it came with the Syclone I bought. It has no shaft play and honestly doesn't look like it's ever been used, but I can't confirm that. I can get some better pictures if someone is interested.
$850 plus shipping or best offer.
SVO
GMC Racing
Re: 58mm Turbonetics turbo
Curious, what turbo are you running on your syclone now ?
atkonkler
Is this your bush?
This turbo will need the Pte style DP to run it also....alot of you already know this....but for those new guys...
Sent from my SM-N950U1 using Tapatalk
Slyclone
Well-known member
...It actually looks like a 3 bolt factory style bolt up down pipe. I do see 4 or 5 around the Flange that is bolted on. with that being said it may be for a factory downpipe. ( just going from what I see )
also, if you put up a picture of the backside we can confirm that as well as if it has been bolted up and spun. not sure but it does look like bit of black soot on the backside inner. ...pictures would tell all.
atkonkler
Is this your bush?
Totally missed that...it maybe has an adapter,now that I look super close...where are my reading glasses!...which makes me interested ! Is the price negotiable?
hutchensce
I'll take some better pictures guys. I'm new to SyTy's myself which is why I say that I don't know a great deal about it.
hutchensce
OK, here are some better pictures. Also, it definitely has been used as there is some black soot on it. My bad.
There's also a part number sticker on it...might try to figure out what it is from that?
hutchensce
Is the one available from Jegs the same as the ones available from RPM? Pretty big price difference is why I'm asking. RPM's Stage 1 is about $1200 whereas Jegs is only about $750. I'm assuming the one from Jegs isn't a bolt-on for a SyTy?
atkonkler
Is this your bush?
How far does this stick out towards the radiator?
atkonkler
Is this your bush?
I wonder If I can still use my RPM CAI tube with a different adapter?
