Silverback
BoostRetard
Has anyone had any luck adapting any of the factory GM stuff to run one? Searching through the old threads it looks like JS was tinkering with it but I don’t know that I’ve ever seen it go past the guinea pig stage.
If so which box are you using? This turbocharged small block that has inspired all these 4L80 questions is currently running a strange conglomeration of GM stuff (‘165 harness repined, ‘730 ecm, everything wired like a ‘749 with a $58 mask out of a sy/ty and, I’ve been experimenting with the $60 stuff from the GM ECM world), so it’s not like a “roll your own” or a semi roll your own solution is going to scare me away, I’d probably actually prefer it.
If I can’t find an answer that I like there I’m probably going to go with the TCI box, since I can’t figure out what makes the others worth 2x or more as much. I know that the Jet setup is just the gm setup with a custom chip, the GM setup is now actually the TCI box with a GMPP sticker on it, and the huges box is just the 3rd controller box (can’t remember who makes it right now) with their name stuck on it.
