4 Link by innovativeairsuspension.com for TY
Loeryder
Re: 4 Link by innovativeairsuspension.com for TY
Not much is different really. ~2" lower for the Ty.
Gas tank and shocks and everything mounts in the same position on the Ty as a 2wd Jimmy...
I honestly wouldn't go with a bolt on 4 link on our trucks.
Too much torque and twisting that 2wd S-series probably don't see all that often.
Silly
Banned
Syborg Twin Turbo said:
i would love to see pictures of this kit
Me too if you get them before me please forward!!!
I can't imagine the rear frame being any different. A AWD 4 link will be setup different than a 2WD 4 link. AWD you want to keep the front tires planted, while with 2wd you would want the weight transfer to lift the front the vehicle to plant the rear tire as much as possible.
schavez
Loeryder, what kind of rear suspension would you recommend? and who makes it?
thanks
Matthew Little
Check suicidedoors.com. They have alot of rear parts for doing 4 links. I am doing a 3 link ladder bar from a gnx and will order my lower arms and mounts from them.
schavez
or what about ladders bars, pandhard with coil overs?
does anyone have this setup and if so do you have any part numbers or where your got it from
I found this on syclone.org, I've emailed him but never heard anything back?
Syborg Twin Turbo
Syborg Twin Turbo
This is the old Al Dustan Set up. Not being made any more.
Although Renz has remade the axle brackets
Loeryder
I would go for a weld in and at this point its pretty much going to have to be custom fit to each truck.
Start with an S-series kit and mod it as needed.
Competition Engineering comes to mind.
http://www.syty.net/forums/showthread.php?t=19366
I'd still like to see someone do an IRS.
jbone
I would like to know more about the setup for the GNX
