4 link + axle + diskbrake setup for the SY? where to get?
sparkwire
Re: 4 link + axle + diskbrake setup for the SY? where to get?
I tought they were 59", search says they are 58 3/8" wms to wms!!
jpalmer
well that would make space/ adapters mot so big when someone goes with Vette wheels. if i kill my diff, i think ill lean this way opposed to a 12 bolt.
warmpancakes
theres 4 different rear diffs
2wd 7.5
4x4 7.5
zr2
the 2wd and 4x4 8.5 rear diffs are the same just different axles
Fast Cars
Can anyone please help me to find a GM rear (3.42 gears), that has the stock width and is beefed up (strong axles, should be able to put in a detroit locker, disc brakes) to hold the planned 1500+hp ?
I am willing to build the 4 link myself, but cannot find a rear that I can use.
Must be avilable anywhere, not?
PLEASE HELP !
syclone383
PLEASE HELP !
Dude, you have the WWW, use it. There are any number of custom rear differential builders out there that will build you whatever you want. Google is your friend. :myclone:
http://www.currieenterprises.com/
http://www.moserengineering.com/
http://www.drivetrainspecialists.com/
Those are a few just to start with and I would recommend you get friendly with your local chassis fabricator as he probably has experience with these manufacturers and others and can guide you in your efforts. You may come to learn that 3.42 gears aren't what will ultimately need for the size tires required to hook up 1500 hp. :2cents:
UR50SLO
V6+2=LSXCamaro
Local Chassis builder in Austraila?
As a couple of the other guy's said...
Contact Moser or currie... they can get the axel narrowed with the ends on it. They could also send you the good axels for the inside/locker/gears depending on how complete you want it.
You would have to weld up the 4link peices for the height of your truck and setup Pinion angle.
Splitting the power is easier on both diffs.. so as others say your good there.
Any Pictures of your setup for us?
~Scott
SY2455
70's Veteran
If you use the search button, you can find what you are looking for. If you don't want to use the search button, I will give you a little help.
http://www.moserengineering.com/Pages/Housings/hous-moser12.html
Now you have a beginning :rotf::rotf:. I think that your weak link may end up being the front diff at this level anyway even though it is only getting 35% of the power or 525 hp.
Fast Cars
I do know the WWW and I am searching it for these damn rears for weeks now.
The comapnaies I found ´mostly didn´t reply to my emails or told me they couldn´t find anythig that fits my needs....
But thanks for the links, I`ve not contacted two of them, so I will do it now.
If I would have a local shop here, I would ask them.........but beeing in Austria,
let me tell you........no way to get any help here ;)
The 3.42 is not what I would choose, but I think I will need to keep them, as I want
to keep the AWD.
And because of the need of 3.42, I´m limited to the GM rears.
Am I mistaken?
Fast Cars
~Scott
I´m from AUSTRIA.......we don´t have Kangaroos ;)
Fast Cars
Thanks.
Yes, Moser was a good link from you guys.
Don´t know why I haven´t seen them when searching for the rears....
Allready contacted them.
I hope they will build me what I want.
