4 bolt main
jwaller
Evil Genius/SyTy Guru
depends. you can use the GM ones which seem to have the easiest install. but do you want straight or splayed?...
Sy769
Here are the ones I used. I had them machine off the splayed bolts on one to use as a front cap. You will need a decent machine shop because many 4.3 blocks are way out of tolerance regarding main cap alignment.
http://store.summitracing.com/partdetail.asp?part=20795'
