JuStBlAzIN
i am woundering if it poissible. i know the proto-sy had it in it. anyone know how to. i serached with no luck.
Tydriver said:well, not to sure its a transfer case issue. I am certain a 3.8L should fit with ease. The transmissions if I remember correctly on the 60* V-6 motors have a different style bolt pattern than the 90* V6 and SBC stuff does.
So if you are intending to use the same transmission you may wanna check again on that. The overall length of the buick motor has got to be as short or shorter than the 4.3L. Would be an interesting swap, however, alot of people here will tell you, you are just making your truck a regular S-10 tho when you do that swap, because mainly it doesnt have a 4.3L in it. Trust me I speak from experience on this :wink:
Actully its been running for awhile, aside from a vacuum leak I have to fix. Turned out all the wiring did plug right in all I had to modify was the digital cluster to fit the blazer dash. biggest problem is the steering which I have'nt finished yet, the steering shaft hits the header and I need a knuckle to move it. The mounts are the old regal frame mount modified to fit. Hopfully I'll have some time here soon to work on it, I've busy with another project.93ty475 said:get it running and add an intercooler or some alky....hotair, huh? did you have to modify the motormount situation?
Tydriver said:The transmissions if I remember correctly on the 60* V-6 motors have a different style bolt pattern than the 90* V6 and SBC stuff does.
