1994 Camaro Z28, 5.7 V8, Asking $2000 FIRM. Upgraded Trans by CPT (Cahall Performance Transmissions) Corvette Servos, upgraded internals, upgraded torque converter, 3.73 GM Gears installed professionally with new bearings, brakes. New Radiator, Water Pump, Alternator, Ignition Control Module, Opti-Spark, Complete front end rebuild including polyurethane bushings for Control Arm, Sway Bar, Ball Joints replaced, Tie Rods, End links, New Trunk Lift Supports, Spark Plugs, Wires, Catalytic Converter, O2 Sensors. Kumho Exsta ASX High Performance All Season Tires with less than 5k on them. Pioneer Head Unit. Cold Air Intake. Custom Programmed. Programming cable and software available for additional $100 - must provide own laptop with serial port. Excellent mechanical condition. Needs some cosmetics to bring it all together. Could use some paint and a little body work but nothing major. Very drivable and fast daily driver right now. Call 302-287-0615 or email venom650everett@comcast.net if you have questions. Car recently took a small hit to drivers side between rear wheel and door - pics are up with this. Car has over $5k invested in mechanical upgrades / performance / etc.
More photos here
1994 Camaro Z28 pictures by phonemanstevef - Photobucket
