1987 turbo t we4 6.0 4l80e 9inch ford 75mm
warmpancakes
Actually a blacked out Turbo-T. More rare than the GN in 1987.
Body needs paint, its pretty chipped up and scratched and the paint is checked bad on the trunk and roof. No real rust though other than on the doors. everything else is pretty solid.
Car also has a 75mm turbo 6.0l LSX with a 4l80E and ford 9" rear end. tune is pretty good for a daily, but its never been tuned on the rollers. according to torque management im making like 580 ft lbs and 609 hp at the crank
Car runs HP tuners, also has manual brakes and manual rack and pinion steering. Very sneaky on the street.
http://s214.photobucket.com/albums/cc192/Grrh77/
The body itself is in very good shape, only rust being on the front bottom corners of the doors like every g-body, and a few small dents here and there. The paint is original and checked on the top areas, but still intact. The front bumper support was cut and the rub strip removed, but no holes have been filled on the bumper.
Since 120k miles, it has undergone a major overhaul.
The body was removed, and everything on the bottom was cleaned, blasted and painted with POR-15. The frame was boxed, and blasted, painted with POR-15.
Poly body bushings, UMI tubular rear control arms, and full front suspension overhaul. Also a TRZ rack and pinon steering was added. In the rear, a new Quick Performance 9" was put in place with a spool, all new internals, 31 spline Moser axles and 1/2" wheelstuds, a 3.07:1 gear and 11" disk brakes.
For the drivetrain, a 2002 LQ4 6.0L was bought with 60k miles, and i made mounts and a crossmember to put it in. Everything under the hood has been cleaned and painted and looks unbeleiveable. I made a turbo system with a facotry manifold, and a stainless log manifold on the pass side. This feeds into a Borg Warner S400 turbo, 75mm, and is controlled by a 60mm wastegate. Heres a parts list for the engine and drivetrain:
6.0L LQ4, 9.4:1 compression
Lunati 224/224-112 .565 camshaft
7.4" Lunati pushrods
Pro Products Typhoon intake
65# Mototron injectors
HP Tuners 2-bar Speed Density tuning
4l80-E trans, fresh fluid and filter
Fuddle 3200 10.5" converter
3" steel driveshaft
9" rear, 31 spline with lightened spool
3.07:1 gears
Moser Axles
1/2" wheelstuds
11" rear disk brakes
Borg Warner S400, 75mm turbo. 1.32 A/R turbine
60mm wastegate set at 9psi
New fuel tank and 255 walbro pump
1/2" fuel feed, with -8 AN braided hose
3/8" return with -6 AN hose
Pro Products FPR with liquid filled guage
4" downpipe
4" exhaust out the back with 2 Dynomax race bullets
Stainless Steel brake lines with new hoses
New manual master cylinder
Stock rims, also 8.5" wide T-Type rims
In the interior there has been little done so far. The headliner is shot, but the seats and dash are in very good shape.
This spring the dash was removed and the firewall was coated with a heat/sound barrier. Also the dash and heater box/ducting had sound insulation applied to them.
MikeRenz
not stock
Re: 1987 turbo t we4 6.0 4l80e 9inch ford 75mm
is this your car? any pics of the entire car put together? price?
sy1907
SYCOTIC
Everyone will be wondering so I'll ask......any idea on $? Any pics of said car put together?
looks like renz just beat me out. bastard you are renz!! ARRRR!
bezerk
i wish my gto was sold. i would buy this thing in a heartbeat..been looking for a GN for some time now. and this has me written all over it.
turbodig
It was a Monster when it was here, just needed a little finishing.
Gary did a lot with it, as I recall.
Raist103
hp seems low but solid car for the price just needs some tlc. to bad no a/c
warmpancakes
why aftermarket ecu? Theres lots of guys making alot more power with HP tuners stuff happily.
because you WILL make alot more power with a performance ECU not a bandaged factory one you can bandaid and patch all you want but you cannot change the basic thinking of the factory ecu and thats emissions
