Stock Turbo Syclone Second Passes but with Alcohol
Vaders Sy
This is a follow up to Stock Turbo Syclone first passes and Syclone dies when FP line off
Originally I planned on going in late September, so I could make some more changes. One of the items I wanted to cure was the hard start when the Sy sits using E85. All I managed to do was turn the idle dial to 9 on the TT for 3% more fuel at start up and while I was doing that, I turned the secondary program on for alcohol. The Sy hasn't sat much since I've done it so, I do not know if that was enough fuel for it to start more easily.
On the TT forums, Eric made some recommendations given my duty cycle was near 100% with 60 lb injectors. I did not turn the boost up as he suggested, I only changed using the alcohol. Admittedly, I have not used it before. I have datamaster files, if anyone wants to review and comment on them.
In short, the Syclone ran about the same times except the last two that were a touch quicker despite it being about 15 degrees cooler, low humidity, and using alcohol. Although the times were similar, or slightly quicker I did get a lot more knock than I did without using alcohol. First the times, then my questions.
First Pass
60' 1.731
330' 5.079
1/8 7.923 @ 85.990
1000' 10.400
1/4 12.508 @ 106.710
Second Pass
60' 1.737
330' 5.097
1/8 7.944 @ 86.070
1000' 10.427
1/4 12.538 @ 106.660
Third Pass
60' 1.735
330' 5.082
1/8 7.927 @ 86.050
1000' 10.402
1/4 12.505 @ 106.990
Fourth Pass
60' 1.740
330' 5.081
1/8 7.918 @ 86.260
1000' 10.390
1/4 12.493 @ 107.060
Fifth Pass
60' 1.715
330' 5.055
1/8 7.890 @ 86.230
1000' 10.365
1/4 12.473 @ 106.770
Datamaster files show knock in just about in every gear. 2nd gear was usually the cleanest. Most of it is 1 - 2 degrees. Sometimes it was as high as 3.5. The highest was 7. Compared to my previous track day that was much hotter and with high humidity, the most knock I saw was 1-2 degrees in 3rd and OD. I did not have any in 1st and 2nd before.
I changed the idle dial for additional 3%, so naturally the fuel table is 3% richer correct?
Using alcohol, how much should I back out of the fuel?
Can there be too much fuel causing knock?
For 1 and 2 Parameters. I thought the lower number (ie 120 or 115 was removing fuel) was a reduction in fuel. I saw more knock, so I changed it back to 122's towards the end. Was I originally adding fuel?
The table on the back of the TT instructions showed a negative number when it comes to fuel when going to a lower number like 128 to 120. I think I might have confused myself because that looked more rich to me where lean is green on datamaster, correct?
AFR was set at 11.5. Truck had about 15-16 lbs of boost. The first pass was at 4 on the gain box. I played around with it a little, but it seemed to like the 3 the best. Either way, the results were not what I was expecting. I think if I would have left it on the original program and raced it like I did a month ago, I would have seen even quicker times.
The plugs were gapped at .028. Eric recommended .025 with more boost and alcohol. I do not remember what plug is in the truck.
Brianawd
Re: Stock Turbo Syclone Second Passes but with Alcohol
The advantage of running e85 comes from being
Able to add in more timing and boost. If you can't do that
Your not going to make more power.
