SOLD: Syclone 1096
ashman
Syclone 1096​
$12,000 firm​
VIN: 1GDCT14Z2M8801096
Mileage: 106,600​
Higher Rez pics: photobucket​
Truck is located in Decatur, AL 35603​
Rods: Eagle CRS5700S6
Pistons: TRW Forged +.030 L2441F
Rings: Speedpro Moly E251K
Oil Pump: Melling 1 pc shaft 689-M55A
Heads: GM L35
Valves: REV Racing SS 2.02/1.60
Cam: Comp Cams 09-412-8
Lifters: Comp Cams 875
Pushrods: Comp Cams 1 piece pushrods
Rockers: Comp Cams Magnum 1.6
T-Chain: Comp Cams 88+ DBL RLR 3136
Gaskets: Victor stock correct head and intake
Studs: ARP main and rocker studs
Turbo: 20G, 57 trim, w/ported stock waste gate
Exhaust: JSM 3" downpipe, 3” MagnaFlow Cat, 3” Dynomax UltraFlo
Injectors: 30lb Delphi, Multec 25324366
Fuel Pump: Walbro 255lph
Thermostat: 160 Degree
Ingition: MSD 6A with Blaster coil​
Engine built by John Waller
Rotating assembly Spintron balanced w/flexplate installed.​
Braking: 2006 Corvette Z51 front/rear, ABS delete kit​
Tires F: 245/40WR-18 Dunlop Direzza DZ101
Wheels F: Z06 18 x 9.5” (painted semi-gloss black)
Tires R: 275/35WR-18 Dunlop Direzza DZ101
Wheels R: Z06 18 x 10.5” (painted semi-gloss black)​
Lowering Rear: Beltech 3” drop springs + 1” drop blocks​
ECM: Tuned for wideband closed loop operation using Code 59 (http://www.code59.org), Moates Ostrich and Innovate LC-1 WB02
3-Bar MAP sensor
Cold air intake
ECM controlled dual electric fans
Accufab adjustable FPR​
Transfer case chain/bearings/seals recently replaced
Bed mounted battery
Bed liner (removable style)
Jeep steering shaft
Ramcharger Dual electric fans (CPU controlled)
Intercooler scoop and Johnson water pump
B&M Trans coolers​
All original parts have been retained and will be included with sale. That includes original wheels with new tires and original tonneau.​
Slyclone
Well-known member
Re: For Sale: Syclone 1096
all i got to say is WOW. that thing is clean and im definatly diging the 4 way disc
JKsSyclone
I've seen this truck in person. It's VERY nice! :tup:
ashman
Sorry, forgot the simple stuff.
Mileage 106,592
The engine had just been built when I bought it and that was around the 100,000 mile mark.
nastety92
Re: SOLD: Syclone 1096
That was a very nice truck and for $12K I think that was a great buy. Theres no way you could build the truck for that kind of money.
Good luck with whatever you end up with next, I'm sure it will be just as detail oriented as this truck is.
Nick
SyTyAddict
I'm glad this truck stayed local, maybe the new owner and I get together sometime. Just curious, did Buzz end up buying the it, I know he was intersted.
QuinnSY
Wow that thing is beautiful!!! What color is the cladding btw, it looks a tad different than the trucks paint, but i'm not sure.
ashman
The cladding is semi-gloss. Not the greatest paint job, but a million times better looking than the faded gray look with streaky armour-all applied :rotf:
