Mikeysy15
Just came back from the track . Had 2 Good licks since I don’t have a roll cage . Truck went 6.29 at 111mph with a warning to slow down and then I sent it with 30psi and a 14psi launch and it went 6.09 at 112.5 with a 1.39 60ft. Track was really good , Da was really good . About 400 over sea level on the last pass and 200 under sea level on the 6.29 pass . Found out my 7.5 limited slip is no good as I was doing a 1 wheel burnout . Still hooked and went 1.44 and then 1.39 60ft . On the last pass my pin on hood flew off. That wasn’t fun . Only changes from my personal best of 6.39 was the 58mm throttle body, ported downpipe head unit , JSM upper and lower control arms , and a pin on hood . Truck was about 100lbs lighter then before.
