what is our trucks cam ??
The_Butcher
Butchery
i'm woundering what is the cam shaft that our truck has is it the same that s10 or s15
cam shaft ?? i need some information about the cam incase repalcine is needed
can any one tell me if i can find the cam and the pistons on summit ??
and about programing my ty computer i need some one to give me some information
thanks for the help guys
90stangGT
Cobra member
Re: what is our trucks cam ??
I'm pretty sure the cam is the same as other s-series trucks. Summit should have or be able to get the pistons and cam you want. Personally, go through one of the vendors that sells here on this board i.e. Hood or Mike Lee. It is a lot easier to get parts from them since will know what you are looking for and are more likely to have these items in stock.
The_Butcher
Butchery
thanks for replying me
realy is it the same cam that s-serios has ??
and about going to one of the vendors that sells here on this board , i tried the RPM
and i find all what i want but the prpblem is they don't take visa and there is some problem about shipping to the kuwait :(
The_Butcher
Butchery
sytyguy said:
thanks for the help hood
but if i chane the original cam to performar one or a higher lift one do i have to programing my ty computer
coz my friend who is a mach told me if you replace any thing stock in ur truck you have to programing ur computer , i don't know any thing about the computer or about how to programing it and i realy need a help with that
thanks again hood
sytyguy
Moderated User
You can get by with a fair amount of changes w/o having to reburn the stock chip. Stay small enough with the cam and you can run the stock chip just fine. Obviously, getting a chip for that combo would be optimal, but you can run the stock chip (you just may spot areas where the tune could use some improvement.)
Hood
The_Butcher
Butchery
Hood
sorry but i don't get it
you mean to the stock cam or use some thing with the same left , what is the maximum thing that i can go with ??
and if i gonna use a bigger turbo with a bigger ingectors also im gonna need a differant chip ??
i know i ask alot and i'm bothering you
sy2675
He Saved the Pimp'n Game!
diff cam, turbo, and injectors are going to need a new chip to run right. :tup:
The_Butcher
Butchery
thanks for ur reply
if i change the cam or the turbo or the injectors , how can i know wich chip i will need ??
and fron where i can get the chips??
sytyguy
Moderated User
I was already writing this so I'll finish. The more things you change that affect the VE of the engine (things like cam, heads, turbo, etc...), the more compensation the chip will need to have in it for these items. What I meant above ("you can get away with.....") was that, often times, there is enough of an operating margin in the stock tune to allow for an increase in certain items w/o having to redo the calibration. Go any bigger or farther out of the operating range and you'll start to see the tune suffer. The AFR will run lean/rich, the timing will want to be adjusted, etc...all of which can be remedied through a chip reburn (within reason...)
As far as how big can you go? There are 2 ways of reading that....1) - How far can I physically go? and 2) - How far can I go on this tune? Cam-wise, you can physically run up to .460-ish lift on stock valve springs (.500-ish on LT1 springs, and even higher on aftermarket and LS1 springs), but you will see the tune suffer for it somewhat.
My advice....set some goals and see what parts you need to get you there. Cams help our trucks, but a stock cam has been pushed REALLY far. Are you sure that you need/want one? Could you get by with stock? Do you just want a lumpy sound? Tons of questions to ask. As far as the chipping is concerned, with your location, I would stay with a proven combo unless you're willing to learn how to tune the stock ECM. This way you can order a "shelf" chip that will work with your combo.
So what are your goals?
