Re: AutoX in Typhoon
Some tips (if you care to heed them).
- Look ahead more. Picking up cones is often a sign of setting up poorly for an obstacle, usually caused by not looking ahead. Road Racing and Autocross share one major aspect and that is the benefit of looking ahead. This gives you time to make adjustments before an obstacle instead of having it sneak up on you and you wind up reacting instead of preparing.
- Set up for the next obstacle with the one you're currently on. Very much an extension of looking ahead, but more specifically, you can make the entry to next obstacle far more strategic if you know how to exit the current one. Walking the course repeatedly REALLY helps here. A common problem with novice autocrossers is not entering the slalom on the correct side (which leads to correct exit). Your club didn't give the option for this by using directional cones, but if given the choice there would have been some benefit to trying the opposite entry sometimes.
- Don't look at the cones....see the corner itself. This was apparent in some of the corners where you were "hugging" the inner radius instead of setting up for the apex. Sadly, apexes can be hard to spot on an autoX course, but it's the visualization that helps with that. For instance, look at the exit of the first big left-hander (the decreasing radius one)....you had the right line at the fulcrum but stayed in a little too much on the last corner cones. That costed you a good 5-10 mph of exit speed (heading into the opposing directional cone gate), which really hurt because that led into one of the long speed sections of the course (this is where you want to capitalize on exit speed (think of Nascar coming off of turn 2 or 4, exit speed wins the race to the next turn).
- Try to read the slalom differently. I usually try to "hit" the cone with my back tire (not really hit, but imagining it that way). If you try to get close to the cone with the front tire, often times, you'll actually hit the cone with the back tire. Instead, try to get that same closeness to the cone, but with the back tire. Next time you're grocery shopping or mowing the grass, practice with the shopping cart or mower. It really helps to see the physics in action there.
- Brake smarter and get on the gas earlier. Overcooking the entry is all to common and can be easily fixed. Work on figuring out the braking zones while walking the course and be conservative on your first 1-2 runs. Delay the braking where it can be delayed (without compromising the line) and then focus on getting into the gas earlier on exit. I noticed a couple of times in the video where you could've accelerated sooner and possibly shaved some significant time off your run. But, it is hard to tell from the video.
All in all, you did quite good....and my advice is just advice.....I'm no pro. I've been racing for many years now, but I still learn a helluva lot every time I autocross. That'll never stop. :tup:
