Turbine vs exhaust pressure
The_Bronze
To start a new thread. 'Dig has got me thinking- that I don't know enough.
I like to diagnose things. I also like to be able to see or document the problem, which is why I like using scopes and such. To that end, I see 'Dig is using the turbine inlet pressure to gauge something.
I was under the assumption that the reduction in pressure and heat (expanding into the turbine) COMPARED to the pressure in the exhaust system was the primary component in what spooled the turbo (I am ignoring at this point turbine design, BB turbo centersections, air intake restrictions, mechanical engine inefficiencies and such). 'Dig is stating that it is not nearly as important as the turbine inlet pressure. I can understand that the turbo wants an extremely hot, high pressure gas, which under the ideal gas law would provide a high potential of energy. My question to 'Dig or knowledgeble others: Looking at the turbine inlet pressure, are you using it as a measurement of the internal combustion process? Turbine "fitment"?
I can also understand that proper cam, ignition timing and adequate (or possibly even some additional) fuel would produce a certain pressure with changes to those reducing or increasing measured pressure. What else would you be looking at? Perhaps a lower pressure than normal as an indication of poor combustion, perhaps say his initial timing mark being off (front dampner), lowering his timing throughout the engine operating range? Is there more there? If this is where you say "this guy doesn't understand a compressor map". You are right, although I have the inital concept and can figure the math to determine where on the map my application would fall. Is the compressor mapping influential in your looking at the TIP? (I just figured out why I had seen that acronym before :oops:).
School me. I'm a fast learner. If you are really tired of beating a dead horse, throw me a few quality links.
The_Bronze
Re: Turbine vs exhaust pressure
Must be secret stuff or such a noob question that people are shaking their heads in disgust.
WyoSyclone
The way I see it is that you have two sides of a device performing work: The turbine side is utilizing heat, velocity, and pressure from the exhaust side to spin a shaft.
The compressor side is using the energy transferred via the shaft to bring in air and compress it to a certain pressure, with a certain flow - it takes a certain amount of torque, transferred via the shaft, to accomplish this.
If you've got a compressor side that is larger than stock it should be capable of moving more air at an equal or higher pressure (boost), but it is going to take more energy to accomplish that task.
If the wheel on the turbine side is a bit on the small side, it's going to take everything that the exhaust has to produce enough energy to transfer to the compressor to produce boost. It would make sense that a turbine side with a larger wheel would be able to accomplish this work in an easier manner (maybe a lower turbine inlet pressure?). Think of the difference between a 1/4 drive socket and a 3/8.. easy to see which one can produce more torque on a bolt.
So, if we have a turbo with a larger compressor section, and a turbine wheel that is a touch too small, it may make for a high turbine inlet pressure. That large compressor wheel is fighting back against the turbine wheel, as the compressor tries to make boost.
What happens if the turbine inlet pressure gets too high and we have exhaust pulses traveling back towards the exhaust valves causing reversion? It is probable that the only cure for this type of situation would be a different turbo, a different camshaft designed to minimize the reversion, or maybe turning the boost down to ease the TIP. And what about compressor efficiency? Maybe the compressor is only efficient up around 20lbs of boost...the only cure then may be a different turbo, or looking at the cam.
Spool up is a factor here as well..... lots to think about, huh?? :D
I'm not an expert on this stuff, as I usually have to dig out all my books when it comes to choosing a turbo.... hopefully the "big guns" will add to this, as I think it is an essential discussion for those of us upgrading our hair dryers. :D
vortecfiero
The old school tuners used to use a turbine size/trim that created a
intake pressure / manifold pressure of up to 2:1
ie 5 lbs of boost with 10 lbs of back pressure
they would measure it with an extra boost guage plumbed into the exhaust system
just before the turbine
In the turbo era in Formula 1 the single purpose set ups saw ratios of .9:1
it was generally accepted that anything more than double the boost in backpressure
was choking the exhaust side to the point of loosing performance
nowadays with the more efficient turbo builds this school of thought will probably have changed
turbodig
That's old-school, all right. :)
I've heard rumors from guys at racing teams of around .75:1 or better being possible. Tough to substantiate that though.
turbodig
To answer the original question - as the others have mentioned here, turbine inlet pressure is used as an indicator of how good the turbine section of the turbo can move air.
In turbo system design, everything is a trade-off. A small exhaust housing will generally spool the compressor side faster than a larger housing, given the same turbine design/shape. The downer is that it will also increase the backpressure (PSI) before the turbo.
In terms of what the engine is seeing, though, we want to look at another number - Turbine Inlet Pressure (TIP) ratio. This is simply turbine backpressure divided by compressor pressure.
The ratio you achieve has profound effects on how the motor produces power, in 2 main aspects -
1) Backpressure causes pumping losses at the crank. Any backpressure that exists in the exhaust manifold must be overcome by the pressure created by the upward stroke of the piston, and this takes power to do. The more pressure present, the more torque you lose on every stroke.
2) High TIP ratios cause lots of reversion. As the exhaust valve is closing, the intake valve is opening, due to the inherent overlap in the cam. (And, our stock cams have a surprising amount given their weak grind) With a TIP ratio > than 1.0, this means that hot exhaust is blowing *backwards* out the intake valve, and back into the intake manifold. This heats up the incoming charge a lot, and also corrupts the clean air/fuel with exhaust byproducts. This makes for a less than ideal combustion cycle, and sets up prime conditions for detonation.
The lower the overlap in your cam, the less the effect, but it's impractical (and undesirable) to have a cam with 0 overlap.
The reality with our stock turbos and many others out there, TIP ratios of 2.0+ are common. 1.5 and less are generally regarded as good, and those nearing 1 are excellent. (And there are cases of even lower than that)
A 2.0 ratio means, that at 20 psi of boost, the crank has to overcome 40 psi pushing down on the pistons, and there's a heck of a good sized push shoving exhaust back into the intake during the overlap period. The more boost you apply, the greater the pressure difference between exhaust and intake- more boost makes the problem worse.
Turbo technology has improved dramatically in the last 20 years or so... such that it's not impossible to have 1.0-1.3 TIP ratios on turbos that have good spoolup characteristics. The best of both worlds.
A < 1.0 ratio, if you're lucky enough to get there, will allow you to do a lot of things with cams and heads that you can't do with larger ratios. Since the compressor pressure is greater than the exhaust pressure, you can run a bit more overlap (and with it, wider lobe profiles) and not see the same reversion problems. And, the more boost you apply, the greater the pressure differential- in a positive sense, this time.
I still see Sys/Tys with turbos that have big, giant compressor sections with tiny 8cm exhaust housings. I'm sure they spool up great, but they aren't making power.
Six-is-Enough
Use to do a little Boost
As always Dig dropping knowledge on the SyTy world..........................
From some reason I always picture Dig sitting in a temple on top of big mountain posting to SyTy.net.:rotf:
WyoSyclone
... and interesting that exhaust system backpressure (in the downpipe) is a component of TIP.
If you have a restrictive exhaust (post turbo) that pressure is actually acting as an adder to total TIP. The reading/studying that I've done indicates a 2.5" downpipe is only good for about 350hp... so, if we're adding a bigger turbo and getting up in the HP ratings, a bigger, more effective downpipe will be a needed, logical upgrade. (an external wastegate vented way downstream in the exhaust is beneficial as well).
To get a good handle on TIP we should really add 2 pressure gauges on the exhaust side -one in the downpipe to see if we have excessive backpressure there, then the second on the inlet of the turbine housing, to see what overall TIP is. Of course, open dumps negate the need for the second gauge.
turbodig
Good point on the post-turbo backpressure adding to the overall... which is another reason that a screwed up exhaust system with mismatched parts needs to go.
The 2.5" DP thing is bunk, though- a 2.5" pipe moves a surprising amount of air. There's been a few guys well into the 500 HP area with that pipe. My Sy went high 11s with it, and you won't do that with 350 HP.
The interior flow area of the turbine (given our usual size turbos) is far more restrictive than a 2.5" pipe is.
Particularly if that pipe has an open dump.
When you start talking larger turbos with larger, freer-flowing turbines and exhaust housings, the flow of the pipe starts to become a factor.
WyoSyclone
That's good to know on the downpipe, Dig.... one more "fact" I can add to my little notebook :tup:
There are so many supposed facts in the books and on the internet that it takes more time to wade through the misinformation than it does to do anything else... appreciate the clarification there :D
brock1949
Its alive!!!
Not to reopen an old thead but i've spent all morning researching the syty forum for answers on my exhaust setup. I'm trying to design the new down pipe, waste gate outlet (where its feeding into the DP, and everything after that.. pipe size muffler etc.
I have a vortec headed 4.3L with a cam close to a 422 and a PT-72GTQ, the intake is a 2114 EFI conversion with a giant plenum and Lsx gen 3 throttle body. Everything is fairly high flow just short of the cast manifolds which i've kept for now in beliefs the cast will hold enough heat etc to the turbo to makeup for the flow restrictions.
Now i'm planning on running 3" down pipe, and once its under the truck going to a 4" pipe to a 4" strait through magnaflow glass pack style muffler then dumping just beyond the cab under the bed for the least amount of pipe. I've got a 38mm Tial wastegate and i'm all over the place with where i'm going to tie that into the exhaust,
So what am i missing, ? Thanks again guys
