I recently bought my second black 93 typhoon, after a six year departure. I never got over the typhoon and it is good to be back! However, the new typhoon was running extremely rough, and I decided to go ahead and get started on my first build-up, which is really just a few bolt-ons big and small (nothing internal). I did a lot of research before the purchases and compared what I read with the experience I had with my first typhoon. Then I assessed my financial status :tdown: and future plans for the ty and this is the initial combo that resulted. I know it has some flaws, but on my budget I felt this was the best mix for performance, while maintaining a healthy daily drivable engine and transmission (probably not so much for the trans., but this is where the budget came into play, and forced my dreams of 4l80's way down the line). In any event, I have the vehicle off the ground on jack stands in my carport and for the most part disassembled. I have been cleaning the upper intake and throttlebody (both are filthy...51,000 miles) and taking my time, but it is getting down to time to start the installation process. And I was hoping for some advice, tips, tricks, etc. Here is a list of the mods that are sitting in my room right now, waiting to be put on after I suck it up and buy a torque wrench and a crescent/flarenut wrench for the number 4 connector (PAS final assembly manual: section 12a, sheet 1) between the turbine and exhaust housing. Here is a list of the mods for which I hope to get any install tips you can think of! Here they are:
three bar map, blitz sbc i-color boost controller, 160 stat, johnson i/c pump, 255 walbro fuel pump, meziere 100 series electric water pump, allstar/ramcharger dual electric fans w/ harness, afpr, new fuel filter, egr delete, 50# injectors, 50# ultimate, pte-44 turbo, airfoil, full ATR exhaust (headers,dp, muffler), ATR external wastegate, borg-warner cap and rotor, and taylor 8mm spiro pro wires, powermaster 140 alt., ngk-ur6's, and most importantly tunerpro software.
I know I need to have 2 of the d/p flange bolt holes slotted. I want to relocate the battery for a cold air set-up using a cone with a short hose to the pte. What is the point of the round plastic vacuum tank that was under the battery tray? I was hoping to relocate the battery there. Another issue I haven't found an answer for yet is the new belt size, minus the water pump/fan pulley. Also, I am considering replacing the metal i/c lines.
Anyway, here are some pictures:
