Syclone/02Blazer
baron4t89
I need some help. I have an 02 Blazer Extreme 4.3L 5-speed, and I want to know if I could drop the turbo setup, or at least part of it, from the syclone/typhoon into my car. I was told that the blocks and the heads are the same. I know that I have 9.25:1 compression ratio and I only plan on running 10 psi. Can someone please help I've looked ALL over the internet but nothing about the swap.
Thanks, Chris
Jimmy
Banned
Re: Syclone/02Blazer
Thanks, Chris
The stock lower intake manifold will not bolt up to your Vortec heads,but can be modified to work.You will need the upper and lower intake manifolds,the exhaust manifolds and crossover,downpipe,wastegate,a turbo,IC,fuel pump.FPR,an ecm/standalone for engine management,and the wiring harness to tie it all together. Among other things.
Thanks, Chris
I am guessing ALL isn't really true, as you might have forgot about the search button on this site. :lol: :lol:
