Signal light conflict issue.
Driven_out
Sonoma Driver
Okay, this is actually not syclone specific, as i'm a Sonoma owner, but since the truck is largely the same as the sy/tys, and some of you are also S10/Sonoma guys, ill ask here as well:
Welp, I started getting a problem in my first gen Sonoma. its a 1992 4.3l with a digital dash, but i recently started getting this issue where the headlights/park lights and taillights would interfere with the truck's signals working. they would only blink when the lights or brake light is off, as soon as i touch the brake or turn on the headlights, the signals would stop working just like that, and I cannot figure out why this would be. has anyone had this issue and know if its a common, easy fix thing?
TY0618
Re: Signal light conflict issue.
I had the same prob. with my '91 Jimmy. In my case it was the 194 bulb in the grille, next to the headlamp. It seemed to work as a marker, but it wouldn't flash. I took the bulb out , cleaned the terminals, and replaced the bulb since it was a pita to access.
Most likely a ground.
X2
If memory serves (Good luck with that.) turn on turn sigs (one side at a time). Have someone watch. Then step on brake. Find the one that "fails." Bad ground is on the other side. At least it's a place to start. Also physically examine each 2 element bulb, Make sure one element hasn't broken and is touching the other one.
HTH
92TYPHOON937
My 85 did this unplug ur reafr lite harness n c if ur front lites operrate fine my rear lites were causing the problem
92TYPHOON937
Its been awhile since it happened I forgot the cause ithats just how I narrwwed it down for me
Driven_out
Sonoma Driver
Thank you guys for the response, ill checkthat out when i get home, but another thing, im surprised i gOt more response here than at the s10 forum
TY0618
Of course! We are a tight knit family here! We are among the "few" who have the joy (and pain) of owning a SyTy, so we try to look out for one another. Besides syty.net is the best corner of the internet!
One other thing you might try. Get a probe with wire and clip, Ground the clip (make sure) then probe the bulb base with your artificial ground to see if you can "cure" the problem that way.
My bet is it's one of the two element bulbs or their ground.
Daryl H
My guess is one of the bulbs is not seated correctly and shorting across the contacts.
Turn on the blinkers and see what lights are too bright/dim or not working all together.
Then try with just the head lights on and see what is wrong.
